Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 01-21-2015, 06:49 PM
paul.allen paul.allen is offline
1999 dodge 3500 van
I was driving my van today about 65 mph and it just died goin down thee road no spit no sputter just like you turned the ignition off, and now it wont crank. Any suggestions?
Old 01-22-2015, 01:17 AM
alloro alloro is offline
Re: 1999 dodge 3500 van
The engine won't turn at all or it turns slowly?
The Following User Says Thank You to alloro For This Useful Post:
paul.allen (01-24-2015)
Old 01-22-2015, 05:11 PM
getting fire to the distributor , but not out of it, I have changed cap, rotor button, and pickup coil still no fire to the plugs
Old 01-23-2015, 12:34 AM
Bad/weak ignition coil.
Old 01-23-2015, 04:34 PM
I'll try that, but a mechanic that has worked on this van before said it has a history of this problem and he had to put two ecm's on it 3 months apart, I got a new ign coil and an ecm coming will try that tomorrow, bout ready to holler !
Old 01-24-2015, 03:21 PM
Thanks for your help Alloro, put a new coil and pcm and it cranked right up! I just hope I dont have this problem again !!!
Old 01-24-2015, 04:52 PM
You probably didn't need the PCM. The reason I suspected the coil was that you had spark going to the distributor just not out of it. That told me the spark was too weak to jump the air gap between the rotor and cap. With a bad PCM you either have spark or you don't.
Old 02-04-2015, 05:48 PM
Got another problem now, heater doesnt get hot front and rear and no air flow from top vents in the rear plenty at the bottom and in the front. any suggestions ? I checked the actuator by turning the temp control knob an actuator doesnt move, so I think thats the heat problem, but still can figure out why no top air in the rear.
Old 02-05-2015, 09:32 AM
Is the engine getting up to temperature?
Old 02-05-2015, 03:37 PM
Yes it is I found the heat problem, the core was stopped up, but the other issue I have now is in the rear, plenty of air flow from bottom vents, but none in the top vents
Old 02-05-2015, 05:22 PM
Sounds like you'll be chasing a broken vacuum line or an actuator with a ruptured diaphragm.
paul.allen (02-05-2015)
Old 02-05-2015, 05:44 PM
would it be located around the rear condenser and blower motor ?
