Old 01-17-2015, 05:00 PM
Firebird1 Firebird1 is offline
Send a message via AIM to Firebird1
Crank Pulley removal
Do anybody out there know which direction the to turn the crank pulley bolt to loosen the Bolt? I'm trying to change the crank positioning sensor and the cam positioning sensor. I have changed the knock sensor. But just can't remove or break the crankshaft pulley bolt. Help!!!!!!
Old 01-20-2015, 08:07 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Crank Pulley removal
Righty tighty, lefty loosey, just like any other normal bolt.
Old 01-22-2015, 03:44 PM
toddrs93's Avatar
toddrs93 toddrs93 is offline
probably going to take air tools to get it off
Old 01-22-2015, 04:42 PM
Stealthee's Avatar
I've done it without air tools many times. I even did it with no one holding the brake. I used a large screwdriver, or a pry bar, and slid it into the rotor vane and let it jam against the brake caliper bracket before applying muscle to break it loose.
Also I used a few extensions to get the breaker bar out past the fender to be able to apply the most amount of force.
Old 05-01-2015, 04:33 PM
Thank you guys for the advise. I'll try those methods.
