2000 Silverado Slides With One Tire On Ice
Hi,
We have a patch of ice around 12" to 18" around 20' long outside of our home. One day, the passenger side of the truck was on the ice and when I pressed on the brake, the pedal went down an inch, instead of the normal 3", and I could feel the ABS shaking the pedal. The truck slid past my home and I couldn't stop it. After some testing, I found that if one tire is on the ice, it will slide, I can feel the rear tire hit the ice and will slide and at some time, the pedal will go down and the truck will stop. I talked to my mechanic and he said that he has never liked anti-lock brakes and this could be normal for my truck. He told me he has gotten other phone calls about this same problem. I'm taking the truck in tomorrow to checked out. I've been dealing with the same shop for years and I'm happy with the service that I get. They're not out to rob me. They have been in business since the 1930s and have a very good reputation. Any thoughts about this problem would be very appreciated. Thanks, Jes |
Re: 2000 Silverado Slides With One Tire On Ice
You just buy this or just move up here in snow country ? Now if your on solid dry pavement and it does this then the ABS needs some work to be checked out also any abs screw ups the abs light comes on....then you have the defective rusted front hub bearings. this is another reason the abs will come on ,,, on solid dry pavement. don't waste your money ...unless you have dash failure lights on !!!!!!! |
Thanks, Jes |
Any recommendations on snow tires? I've seen some that are made to have better traction on ice. How about Studded snow tires? I have all season tires. right now.
Jes |
having owned this vehicle 2000 silverado LT 4X4 this is what it is.. also watch out for bumps in the road because even on dry pavement the tires can bounce and then the same thing happens... |
the blizzack snows work the best. on ice nothing works. with 4WD usually AT tires is all you need . this is what I have on my 2000... if 2wd then you will need these blizzacks.. also add 400-500LBS in the bed..plastic covered sand bags home depot has them..
Thanks, Jes |
