Go Back   Automotive Forums Car Chat > Kia > Sedona | Carnival II
Old 01-08-2015, 08:01 AM
groovyforster groovyforster is offline
2002 Sedona Misfire Counts
I have a 2002 Sedona that has codes for misfires in cylinders 2, 3 and 6. I figure 3 is misfiring due to a bad wire as this set-up uses the slave wires. I'm thinking that cylinders 2 and six are misfiring due to bad coils. In this case I would like to use a scan tool to see if these cylinders are misfiring in real time data rather to swap coils and see if the code changes with the swap. Therefore, does anyone know of a scan tool that will display misfire counts for this vehicle. My Tech 2 does it for GMs but I can't use the Tech 2 for the Kia.
Thanks,
Groovy
Old 04-14-2015, 10:18 AM
rhandwor rhandwor is offline
Re: 2002 Sedona Misfire Counts
I would use noid lights and make sure your getting good pulses for the injectors. You can use a logic probe and monitor ground for the coils.
I would check the timing belt for damaged teeth normally a problem on one side is a timing problem. If you just installed a belt you may be a couple teeth off.
