Old 06-29-2003, 04:41 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
check engine light means...??
the check engine light in my civic came on when i was driving on the highway at around 70mph. what could be wong? my car is at 141,000miles.. the oil has been changed and doesnt leak.. coolant is ok. radiator is new..
it lights up and stays on when i drive a couple of miles. what could be wrong? could it be the oxygen sensor or something? how would i be able to fix it?
Old 06-29-2003, 04:48 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Re: check engine light means...??
When your check engine light comes on, your ECU will throw a trouble code... to find out what code it is, you have to pull back the carpet on the passenger side foot-well where the ECU is mounted. Then, you put the key in the ignition and turn it to the 2nd position (don't start the engine), and there's an LED mounted on the ECU that will blink. Count how many times the LED blinks and that is the code:
Code 1 (1 flash) Oxygen content
Code 3 or 5 Manifold absolute pressure
Code 4 (4 flashes) Crank angle sensor
Code 6 (6 flashes) Coolant temperature
Code 7 (7 flashes) Throttle angle
Code 8 (8 flashes) TDC position (top dead center) timing
Code 9 (9 flashes) No. 1 cylinder position (1.6L)
Code 10 (10 flashes) Intake air temperature
Code 12(12 flashes) No code 11 don't know why. Exhaust gas recirculation system
Code 13 (13 flashes) Atmospheric pressure
Code 14 (14 flashes) Electronic air control (EACV)
Code 15 (15 flashes) Ignition output signal
Code 16 (16 flashes) Fuel injector
Code 17 (17flashes) Vehicle speed sensor
Code 19 (19 flashes) No code 18 for some reason Lock up control solenoid valve
Code 20 (20 flashes) Electric Load
Old 06-29-2003, 05:47 PM
bionictony's Avatar
THANKS A LOT ci5ic. i got 12 blinks... exhaust gas recirculation system? what does that mean?
Old 06-29-2003, 07:37 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
be sure to count the blinks more than once. it's possible to have more than 1 error code. also...don't count the first flash. it gives 1 flash just to let you know the ecu is working. here is the info that is posted at www.4thGenerationCivic.com
"With the ignition on the ECU will display a single flashing light indicating the system is operating. When the ecu sets a trouble code,the check engine light will come on and the ecu stores the code in the memory. The trouble code will remain in the memory until voltage to the ecu is disconnected. Removing the hazard fuse in the main fuse panel for 10 seconds will reset all trouble codes. Reset the memory after repairs are made. Make sure the ignition is OFF when disconnecting the main fuse. "
i have owned many (lol, to say the least) 4th gens. this is my experience with error codes. every now and again, you just get them. if the car has been running fine then reset the ecu and see if you get another code. if not and the car is fine then just and don't sweat it. i got a Code 13 (Atmospheric pressure) one day reset the ecu and have never got that code again in 2-3 yrs.
have you noticed any other symptoms with your car?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 06-29-2003, 08:35 PM
turbcivic's Avatar
turbcivic turbcivic is offline
sounds like an o2 sensor. Honda wants 170 for one at my cost.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 06-29-2003, 08:55 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
fuck that you can get em for like $50 places around here.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 06-29-2003, 10:01 PM
91civicDXdude's Avatar
the check engine light means you have to slam on the brakes, pop the hood, and hurry up and get out and check sure the engine is still there
Old 06-29-2003, 11:49 PM
bionictony's Avatar
haha.. funny.. but yeah.. there are like no other problems with the civic.. it drives perfectly even though the check engine light is on. everything seems normal. the temp gauge doesnt rise higher than normal. thanks for the reset advice.
Old 06-30-2003, 12:15 AM
ci5ic's Avatar
Actually, I was driving home from Idaho on Thursday, and my check engine light came on, so I pulled over, turned the car off, and when I turned it back on, the check-engine light didn't come back on, and the ECU didn't throw any codes... weird... I suppose that if it was a real problem, the light would've stayed on or the ECU would've gave me a code or something...
Old 06-30-2003, 03:04 PM
amy@af's Avatar
okay then, reset the ecu and see if the check engine light comes back on
you say the car runs fine so i doubt it will come back on
