Old 12-28-2014, 10:43 AM
clauritzen clauritzen is offline
Exclamation Need P0446 Code Help
I have a 2001 1500 with the 5.3V8 motor (ext. cab sb 4x4 LT). I was my dads and had the service engine light on for a long time for the P0446 code. I replaced the vent valve and the purge valve and light keeps coming back on. Usually can go for a day or so and then it comes back on and I get the same P0446 code. Can someone give me some ideas on what else may need to be replaced?
Thanks!
Old 12-28-2014, 12:03 PM
aleekat aleekat is offline
Re: Need P0446 Code Help
I had a similar issue on a dodge ram 1500. Had some split hoses attaching to the valves.
http://www.samarins.com/diagnose/p0446.html
Post back, that's what makes Forums Work.
Old 12-28-2014, 01:47 PM
j cAT j cAT is offline
Thanks!
the 446 is a small fuel tank/system vapor leak. venting / purge solenoids as well as the canister/gas cap/leak in the fuel filler pipe, fuel vapor lines. common would be stuck open solenoid venting/purging valves/cracked canister. new silverados have bad tank pressure senders.. with 2001 I would guess at vapor lines/cracked canister/stuck solenoid valves.
Old 12-31-2014, 10:29 AM
MikeD268 MikeD268 is offline
Just went through this myself with a nearly identical truck. Check my thread out here http://www.automotiveforums.com/vbul...33#post7153133
