Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-27-2014, 11:19 PM
Sabot15 Sabot15 is offline
Coolant in Cylinder??
I have a 96 Oldsmobile cutlass supreme with 92k and the 3.1L V6.
It recently developed a miss on cylinder #1. I have a small amount of coolant in my oil and some sludge in my radiator. I assumed it was probably the lower intake manifold gasket that was had failed, but I noticed something weird.
When I removed the spark plug on #1, and I turned over the engine, antifreeze shot out.
When I look at the way the manifold fits, I don't see any way that pure coolant could get directly from the jacket journal to the intake journal. I am assuming then, that this MUST be a head gasket failure, or a cracked head. Is that correct?
Thanks!
Old 12-28-2014, 06:08 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Coolant in Cylinder??
coolant in the cylinder pretty much always means head gasket.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 12-30-2014, 09:20 PM
Tech II Tech II is offline
9 out of 10 times, when there is a head gasket leak, it cylinder #1......if coolant comes out of the spark plug hole, it's the head gasket, or worse case scenario the head.....you will usually see separation in the gasket if that is the problem......the head should be sent out to be checked.....
