Old 12-25-2014, 06:04 PM
Elitemduane12 Elitemduane12 is offline
Leaking Fuel 97 gtp
Lines are a bit rusted. I'm not sure which lines are which. Can any of u determine what I probably will need to replaced. I'm about to give up on this car honestly, so I'm not looking invest to much in repair.
Old 12-25-2014, 09:50 PM
Tech II Tech II is offline
Re: Leaking Fuel 97 gtp
When I see a car from New England, mid to late 90's, you can almost guarantee that the fuel AND brake lines underneath the car are rusted and on the verge of leaking........nature of the beast with the salt used on the roads around here.....also find problems with the front cradle bolts due to the same thing....
In your case, it could be a domino effect......all 5 lines are bad...you try to repair one and just moving an adjacent one, can cause that to leak......COULD BECOME VERY COSTLY.....
Old 12-26-2014, 11:41 AM
DeltaP DeltaP is offline
'Word'. The wet one is the offender and his 4 buddies are the maypops. It can be fixed but it's very time consuming and alot of work.
