Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 12-21-2014, 11:02 PM
Cheybree Cheybree is offline
Angry 02 escape oil in trainee vice versa HELP
I have a 2002 ford escape and I don't know how I did it but there is oil in the trainee fluid and trainee fluid in the oil. Any suggestions to how this could have happened and how to fix it. My car runs but after the fluids mix together none of the gears work. I did not feel the transmission slipping at all!
Old 12-22-2014, 08:06 AM
65comet's Avatar
65comet 65comet is offline
Re: 02 escape oil in trainee vice versa HELP
You need a new radiator. Stop driving it. The radiator broke internally between the tranny cooler and anti-freeze wall. The anti-freeze will mess up the clutch packs in the trans, cause them to swell then fall apart. Then that can lead to real expensive repairs. Even if they don't fall apart, their swelling can cause the clutch pack housing to crack and it will stop containing proper pressure inside it. Get the new radiator in. Then get it to a trans shop and have them do a complete flush to get all the anti-freeze out of its system. The radiator swap will drain out the anti-freeze side. You should do a flush on that as well since the radiator hoses aren't designed to handle trans fluid. It can soak into them and make them soft.
If you say it won't move now, it might be too late for that trans.
