Go Back   Automotive Forums Car Chat > Proton > General Discussion
Old 12-18-2014, 07:06 PM
linfu299 linfu299 is offline
150W 12VDC CV TRIAC/ELV dimming LED Driver
Item:EUP150T-1H12V-0
Input Voltage:40-240VAC
Output Curren:12.5A*1Channel
Output Voltage:12VDC
Output Power:150W
Dim Mode:riac/ELV
G.W.(g):1115
Size(mm):260*78.3*45
Model: Eup150T-1H12V-0
Feature:
◇Single-channel constant Voltage 12VDC output, each channel 12.5A Max.
◇Support Leading edge (Triac) and Trailing edge (ELV) Dimmer.
◇Dimming range from 40VAC to 240V AC.
◇High efficiency: up to 87%.
◇Output short circuit protection; Overpower protection; Over temperature protection.
Technical Parameters
Output Channel
1Channel
Input Voltage
40-240VAC
Input Frequency
47/63HZ
PF
≧0.5(230VAC)
Efficiency
≧87%
Dimming Mode
Triac/ELV
Output Voltage
12VDC
Output Current/Each Channel
12.5A
Output Power
150W
G.W.(g)
1115g
Size
196mm*75mm*40mm
Working Temperature
-20℃ - 50℃
More information from http://www.euchipsonline.com
Tags
dimming , driver , led
