Old 12-16-2014, 01:22 PM
Fred Bear fan Fred Bear fan is offline
Engine ticks allot when warm only
Hello everyone. My 1999 cavalier 2200 ticks insanely when its warm so much so its almost embarassing at a drive thru ! But it goes away when the RPMs go up . Any idea where to start? Thank you!
Old 12-17-2014, 04:15 AM
Blue Bowtie's Avatar
Registered Offender
Re: Engine ticks allot when warm only
Connect a mechanical gauge and read actual oil pressure when the engine is at full operating temperature. If it is below 10 PSIG the lifters are probably draining and unable to take up the lash of the valve train.
Old 12-17-2014, 04:29 AM
Awesome. Will do and thanks again. I am AMAZED how much BS is out there when looking for a specific answer but I think you nailed it !Thank you and I will post the results once I get to it, Thank you again sir !
Old 02-04-2015, 10:27 AM
Greeetings . I Put in the suggested synthetic oil. No improvements. Still ticks like hades.Any other suggestions?
I did not do a oil PSI test as I did not have access to the correct lines/guage
