Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 12-14-2014, 08:42 PM
donhoward49 donhoward49 is offline
speedometer
2002 Liberty sport. Daughter said the speedometer is going crazy registers 10 or 30 on the highway, Let off the gas and it dips down more... I thought power or ground.. Battery is 18 months old..
Thanks,, Don
Old 12-27-2014, 05:53 PM
dagwan11 dagwan11 is offline
Re: speedometer
You need to find where your VSS( vehicle Speed Sensor) is located. On my 2005, it is located top of the differential. There was an issue at one time of the VSS wiring chaffing the emergency brake cable. I had so many issues with this stupid sensor like no speedometer, power locks not working, erratic speed, no cruise control, and of course the check engine light on. The sensors are pretty cheap( Amazon carries them). Hope that helps.
The Following User Says Thank You to dagwan11 For This Useful Post:
donhoward49 (12-27-2014)
Old 12-27-2014, 08:26 PM
Re: speedometer
Thanks, Mine seams to have two VSS, on the transmission. I replaced one, check enjine light went out but speed is still eratic,, Guess I will replace the second one..
Thanks
