Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 12-13-2014, 04:44 PM
tkswan's Avatar
tkswan tkswan is offline
rear control arms
2002 LS V8 204k miles. I need rear control arm bushings. Are they replaceable or do I have to buy the whole control arm?
-tswan
Old 12-15-2014, 08:27 PM
tkswan's Avatar
Re: rear control arms
Okay, I am replying to my own post. I just spent over a lot of money on two front upper control arms, front tie rod ends, and struts and shocks, including new strut mounts all around. As of late the steering wheel went of center, about 15 degrees in one trip. I took it back to learn that the rear right wheel was the cause. The bushings are gone, (still skeptical of why they didn't notice that when doing the shocks). The rear control arms are outrageous to replace. I found a site www.energysuspension.com.
I need to measure the bushings and then order and replace them myself. The problem is taking it apart, measuring bushings and then waiting for the parts. I am looking for opinions on doing this because the bushings were not meant to be replaced. The specs say to replace the arm itself. Thoughts?
-tswan
Old 12-15-2014, 09:51 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Maybe you'll find someone that has a 2-piece bushing in the correct diameter so you can cut/press out the old bushing and then install a new bushing. Either that or you may need to get creative with injection molding RTV rubber.....
-Rod
Old 12-16-2014, 09:57 AM
tkswan's Avatar
-Rod
I found www.energysuspension.com. they want the dimensions and they will create the bushing for me. I should be able to get dimensions from somewhere without taking it apart and putting a ruler on it shouldn't I? Have you ever heard of that web site?
I just learned that www.energysuspension.com. makes non rubber (polyurethane) replacement bushings. Polyurethane will cause lots of noise vs rubber bushings. So thats out.
-tswan
Old 12-16-2014, 12:50 PM
shorod's Avatar
SHO No Mo
I've used Energy Suspension bushings before. Yeah, the poly bushings are a bit stiffer, but I'm not sure I'd classify it as "lots of noise", and they may be about your only affordable option.
You might want to check around on Jaguar enthusiast sites and maybe even Thunderbird enthusiast sites since the same platform was used for one Jag model (S-type?) and the newer Thunderbird. Maybe someone with one of those cars figured out a solution for the same issue.
-Rod
Old 12-18-2014, 03:37 PM
tkswan's Avatar
-Rod
Hmmm, ok. So now i'm hearing/reading that the LS rear control arms provide a service when the car is turning, they allow the car to slightly "crab" when turning (like around quick winding streets) at posted + speeds, as well as an assist of the weight distribution of the whole suspension. There are no replacement bushings that will allow that crabbing to continue. Replacing them with aftermarket bushings will change the performance of the rear suspension. Ever heard that story?
-tswan
Old 12-18-2014, 09:12 PM
shorod's Avatar
SHO No Mo
I've not heard that concept but I don't really doubt it. Those bushings always seemed a bit large. That size might be explained by the need for significant compliance to allow that "crab" function.
-Rod
Old 12-22-2014, 04:52 PM
shorod's Avatar
SHO No Mo
I sent you a Private Message with some information that may be of use.
-Rod
