Old 12-07-2014, 02:18 PM
C_Four C_Four is offline
Headlights charge my battery; huh?
Ok, let's see who's run across this before. Vehicle: 07' Pontiac Grand Prix. Charging system voltage slowly drops while the engine is running. However, if the headlights are turned on the charging system returns to normal operation. Foot note; high beams come on sometimes when either blinkered is turned on....
Old 12-07-2014, 03:15 PM
aleekat aleekat is online now
Re: Headlights charge my battery; huh?
Sounds like a grounding issue. I would check and clean every ground you can find.
Post back, that's what makes Forums Work.
Old 12-07-2014, 04:22 PM
Thanks aleekat. I had thought that originally with the high beams/turn signal issue, but really didn't think that would have such an affect on the charging. I'll check it out and let ya know how it goes.
Old 12-07-2014, 05:26 PM
Well aleekat, am guessing you already knew what the results would be; but, it worked. Thanks a bunch..... quick easy fix!
Old 12-07-2014, 06:22 PM
Good deal. Thanks for the update.
Tags
alternator , charging , electrical
