Old 12-07-2014, 10:18 AM
afxracing's Avatar
afxracing afxracing is offline
Restoration Body Dolly
Not sure if this is where I should post this but here goes anyway.
I like to display my works in progress on stands or jacks. I have quite a few versions already but I did not have a body dolly.
So I decided to build one.
Mine will be 50mm on the short side and 60mm on the long.
Use the lines on your cutting mat to make sure the sides are perpendicular.
Motorsport Modeling
Old 12-07-2014, 10:35 AM
afxracing's Avatar
Re: Restoration Body Dolly
Cut some triangular gusset plates from .010 sheet to reinforce the corners.
Motorsport Modeling
The Following 2 Users Say Thank You to afxracing For This Useful Post:
Loloskymaster (12-08-2014), lovegt40 (12-07-2014)
Old 12-07-2014, 10:39 AM
afxracing's Avatar
Cut the legs from the same square tubing. My legs are 8mm long.
Install them in the corners with top resting against the gusset plate.
Motorsport Modeling
Old 12-07-2014, 10:44 AM
afxracing's Avatar
Layout some holes for the body posts around the perimeter of the frame.
Make the post from solid rod, I am using .062 and are cut to 10mm in length. Punch out some bearing plates from .010 sheet.
Motorsport Modeling
Old 12-07-2014, 10:46 AM
afxracing's Avatar
Glue the bearing plates to the top of the body posts but don't glue the posts into the frame. That way you can adjust them to fit whatever car you are working on at the moment.
Motorsport Modeling
Old 12-07-2014, 10:52 AM
afxracing's Avatar
Now we will make the casters. Cut wedges again for the same square tubing then open the narrow edge.
Slices the wheels from some solid rod the inside width of the bracket. I am using .125 rod.
Cut some bearing plates for the top of the casters from .010 sheet. Mine are 5mm square.
Motorsport Modeling
Old 12-07-2014, 10:55 AM
afxracing's Avatar
Glue the bracket to the bearing plate and the wheel to the bracket. Then glue the caster assembly to the bottom of the legs.
Motorsport Modeling
Old 12-07-2014, 10:56 AM
afxracing's Avatar
This is what it looks like after painting.
Motorsport Modeling
Old 12-07-2014, 10:58 AM
afxracing's Avatar
So now you can show your works in progress like this.
Motorsport Modeling
The Following 3 Users Say Thank You to afxracing For This Useful Post:
lovegt40 (12-07-2014), sprite46cfk (12-07-2014)
Old 12-07-2014, 11:31 AM
Loloskymaster Loloskymaster is offline
Eh, nice idea for this dolly!
Maquette Club Thionvillois is here! http://www.mct57.org/
Old 12-07-2014, 12:41 PM
88Porsche944 88Porsche944 is offline
Old 12-19-2014, 05:18 AM
guillote68 guillote68 is offline
Superb!!!!!!!
Thanks for share with us..
Guillermo
Buenos Aires
Argentina
Old 12-19-2014, 07:09 AM
afxracing's Avatar
Happy to help. Glad you guys like the tutorial.
Motorsport Modeling
Boreham (12-19-2014), Lee Yoder (12-19-2014)
Old 12-19-2014, 07:11 AM
Boreham Boreham is offline
excellent..
It's a nice project with basic materials.
I was gonna ask when I seen the Mk2 on the trolly... "where did you get that"
simple solution on the casters..
Old 12-19-2014, 04:59 PM
RonCla's Avatar
RonCla RonCla is offline
Thats a great project. Well thought out and excellent execution.
