Old 12-05-2014, 01:57 PM
kcducttaper kcducttaper is offline
looking for .009 undersized bearings - or modify my .010
Long story short, I bought a reman'd crank that came with "matching" .010 undersized bearings, so I didn't bother to plastigage them when I put it in. Mental note - ALWAYS personally double check EVERY machine work you have done on ANYTHING. After thinking through the list of symptoms, I decided to pop off a rod cap and check the clearance. The plastigage was squished to literally twice the thickness of the .001 strip, so I'm guessing actual clearance is somewhere around .0005. The specs call for at least .0015, so I'm at least .001 too tight on the rod I checked. If I'm lucky, I just got a set of bearings that were out of tolerance somehow. I'll be measuring the crank with micrometers and comparing that to the original specs tonight to see where I'm at. If the crank turns out to be only .009 smaller than original instead of .010, is there a relatively easy DIY way to get my clearance within the specified range? Something like a .009 undersized bearing instead of the .010 that came with it should work nicely I would think, but I can't find anything of that nature.
Old 12-05-2014, 02:37 PM
maxwedge maxwedge is offline
A990 racer
Re: looking for .009 undersized bearings - or modify my .010
Make sure you have fresh plastigage it can have a shelf life if any of the wax has melted to the paper. No such thing as .009 bearings of course unless order them custom made. Hard to believe that much of an error resizing the crank.
Old 12-05-2014, 05:42 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
back of the plastigauge will have the thicknesses shown. like he said try some new stuff. make sure you wipe all the oil off before you check it again. if clearance is still to tight you will need to send the crank back in to get re-turned. i have seen people use 000 steel wool to make them slightly larger for more clearance but i would not recomend doing that
Old 12-05-2014, 06:32 PM
Well, I just measured the crank and it's just a touch under 1.957 according to my micrometers. Eyeballing it (I don't have marks for tenths), it's at 1.9568. The factory size is supposed to be 1.9675 max, so it appears at first glance that the crank is pretty much dead on target. Is there a good way to measure the thickness of the bearing to see if it's just a hair thick? Something is .001 - .003 too big and I'm trying to figure out what instead of just chucking parts at it. Something like an OEM bearing thickness would be ideal, but I can't find any such documentation on the webz.
One thought I had was to put a spacer between the cap and rod, but that would only fix one axis and would make the hole oblong, which is probably no good.
Old 12-05-2014, 06:45 PM
Crvett69's Avatar
why was crank replaced? if it had a rod knock or other lower end damage its possible the rod end are out of round but before you go tearing more stuff apart got get some more plastigauge
Old 12-05-2014, 09:29 PM
Turns out the bearings were a tad long, so it buckled the bearings a tiny bit when torqued down.
