Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 12-02-2014, 09:53 PM
jooboyle jooboyle is offline
Clutch change in a gtra
I'm a new member and my recently purchased Panoz GTRA clearly needs a new clutch, so ...
How do I change the clutch in a GTRA? I have the drive shaft removed and the trans is detached from the bell housing but now I'm wondering if there is enough room to pull the trans off the bell housing and get it out of the car. (I have not pulled the input shaft from the pilot bushing)
Your guidance is most welcomed
Thank you
Old 12-11-2014, 12:47 PM
NZGTRA17 NZGTRA17 is offline
Re: Clutch change in a gtra
Thank you
To do a clutch change with the engine installed I believe the only way to do this is to remove the trans tunnel and pull the trans up and out through the tunnel hole inside the car.
To do any clutch work I normally pull the engine out as I have this down to around 2 hours anyway.
Kel.
Kel M
Panoz GTRA #17
New Zealand
