Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-02-2014, 05:34 PM
dakotadave83 dakotadave83 is offline
'93 3.9 Low Rumble from Engine
Engine is a high milage (over 150,000) one. Truck is manual transmission. Above 2000 RPMS, low rumble noise and vibrations felt through gear shift lever.
Only hear it when engine under load. Ideas? I think its worn crank bearings...
Old 12-02-2014, 07:02 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: '93 3.9 Low Rumble from Engine
it could also be worn bearing in transmission or low fluid or maybe a bad u-joint that is only stressed under load. worn engine bearings usually result in a knock or thud sound not a vibration
The Following User Says Thank You to Crvett69 For This Useful Post:
dakotadave83 (01-11-2015)
Old 01-11-2015, 12:05 PM
Thank you for the reply! Was hopin it ain't the crank/cam bearings! Will check the U joints then figure out how to check the transmission bearings!
