Old 12-01-2014, 06:21 PM
mvrick208 mvrick208 is offline
Material used on crankshaft pins and main engine bearings
Does anyone know what materials are generally used on crankshift pins that rotate inside main engine bearings and what materials the bearings are made out of in Formula 1, normal everyday road cars, sports cars etc. Thank you.
Old 12-01-2014, 06:32 PM
Re: Material used on crankshaft pins and main engine bearings
I found one material for the crankshaft which is cast using steel alloy or forged using heat treated steel alloy. Is this generally the same for formula 1 too?
Old 12-01-2014, 07:05 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
most performance cars used forged steel internals including crank and wrist pins
The Following User Says Thank You to Crvett69 For This Useful Post:
mvrick208 (12-05-2014)
