Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-30-2014, 10:11 AM
Peevee Peevee is offline
2010 Impala dual heat problems
My wifes impala has developed a problem. The passenger side is stuck on heat. The drivers side works fine. Any ideas on what is wrong?
Old 11-30-2014, 08:01 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2010 Impala dual heat problems
Most likely the passenger side temp door actuator has failed and will need replaced. Not too tough a job. A scanner that can read "B" (body) codes would probably show a code.
The Following User Says Thank You to gmtech1 For This Useful Post:
Peevee (12-04-2014)
Old 12-04-2014, 08:38 AM
Thanks I got the heat fixed. It was the actuator. I have another problem now. I was driving to work yesterday and the horn started blowing. It was just like I was the holding the horn button down. I pulled off the road and turned the ignition off and it quit. I started it back up and drove to work fine. Later the office people came and got me and said my horn was blowing. It had quit by the time I got outside to check it out. Any ideas? This car is really getting on my nerves. Thanks
Old 12-04-2014, 09:27 AM
gmtech1's Avatar
If the car were 20 years or so older I'd say there is a problem with the horn switch, but I don't see those very often anymore. I'd replaced the horn relay (underhood fuse box) and see if that takes care of it.
Old 12-04-2014, 04:19 PM
Tech II Tech II is offline
Horn shut down when the key was turned to off? That kind of eliminates the relay, but would also be the first thing to try....otherwise the control circiut to the relay has to be checked out....could be a shorted line, bad switch in steering wheel, or problem with the theft deterrent circuit...
