| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
all of the above, heater, odometer(digital), radio, wipers and the temp gauge quit working. Thinking ignition switch so I changed and no help. Open to ideas... Maybe a ground somewhere and the location. Pictures will help alot! It is a 2001 silverado with a 4.6 and niothing special as far as the electric windows etc.. I am working on this in my garage at home on my spare time but getting frustrated with it. Thanks
#2 | |
Re: 2001 chev siverado heater, wipers, radio, odometer dont work and changed the ign. switch
I looked at my 2000 alldata and a ground is under the seat close to wiring connector. Another one is at the back of the motor close to top of transmission. Check for a blown fuse.
| The Following User Says Thank You to rhandwor For This Useful Post: |
jeffnelson (11-26-2014)
#3 | |
I have looked and tested ALL fuses. I on the other hand did find a broken black wire under the floor mat when looking at different spots. Could this be the culprit? Just a small black wire? It does have a ground block then under the driver side of the seat then right? I will check and let you know. THX...
#4 | |
there has to be someone with similar problems that can give me an idea of where to look?
#5 | ||
also what engine is this V8 or the V6 ? these circuits are not common electrically , so I would think that this vehicle was messed with .. how long you owned it/any aftermarket crap on this ? on the rear of engine back of intake manifold area is a ground connection G103 make sure is solid and clean. |
| The Following User Says Thank You to j cAT For This Useful Post: |
jeffnelson (12-10-2014)
#6 | |
For $26.95 you can get a 1 year subscription to AllData DIY. It's the same as having factory manuals.
http://alldatadiy.com/buy/
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
| The Following User Says Thank You to 777stickman For This Useful Post: |
#7 | |
not sure if they did it in the trucks, but in the 01 cars, there is a BCM. Body Control Module. it should be under the dash on the drivers side. it is something that only a dealer can redo. when replacing it, the dealer has to reprograms the BCM. they are a program once only module. it controls radio, heater, windows, door locks, wipers, lights, anything that is considered part of the body system.
