Old 11-23-2014, 06:48 AM
afxracing's Avatar
afxracing afxracing is offline
Ford Escort RS1800
I am going to try my hand at building the old Esci kit. I will be borrowing many ideas from Petri Huhtala's excellent build which you can find here.
I have not fully decided on the livery yet but here is the kit I am starting with.
Motorsport Modeling
Old 11-23-2014, 06:53 AM
afxracing's Avatar
Re: Ford Escort RS1800
I start with improving the fit of the hood.
Motorsport Modeling
Old 11-23-2014, 06:56 AM
afxracing's Avatar
There was always something that didn’t look quite right to my eye about the rear flairs on the kit. I have heard many people say that the flair should not extend above the body crease. Yes there are versions of the car with the top of the flair below the belt line. However there are also versions with it extending above the belt line. So that wasn’t it.
After studying many photos of the 1:1 car I think I figured it out. The top of the rear wheel well on the kit is too low. If you draw a line through the apex of the wheel wells it should be parallel with the belt line.
You can see this in the photo on the bottom unaltered car. The car on top I have raised this apex about 1mm (one scale inch) to bring the lines parallel.
It is a small change but I think it makes a big improvement.
Motorsport Modeling
Old 11-23-2014, 10:51 AM
generationx's Avatar
generationx generationx is offline
You're making a good professional start to this venerable kit. My advice would be to take care of the spacing of the front wheels, it makes or breaks the look of the finished model.
The rear arches are correct for certain tarmac-spec versions of the "Works" Mk2s, but not all so check your references. Also if you really want to get this "correct" you need to do serious surgery on the rear suspension and floor pan. Good luck, I'm watching with interest!
Old 11-23-2014, 04:36 PM
afxracing's Avatar
Yea its curious that Esci would choose to model a tarmac car. The RS1800 was never very good on that surface. It made it's legend in the forest and the gravel rallies. I am currently modifying the suspension and will mock it up the get the stance correct.
Motorsport Modeling
Old 11-24-2014, 02:46 AM
Ford Escort mk 1 Ford Escort mk 1 is offline
Hi
Really nice start for this Project =)
Take a look of these pics, some motivation for building. Revell/ Esci kit really need improvement to the bottom of the car =)
Credid to the pics: Spede
Regards
The Following User Says Thank You to Ford Escort mk 1 For This Useful Post:
chris24 (11-24-2014)
Old 11-24-2014, 07:25 AM
afxracing's Avatar
That's a nice looking transkit. Where did you get it? It would save me a lot of work.
Motorsport Modeling
Old 11-24-2014, 09:13 AM
Hi,
This kit is made in Finland =) By: Petteri Nyholm. you can send him mail.
But last time we spoke he told that the molds were used and he was think about if he made a new ones.
Here is his profile
http://www.automotiveforums.com/vbul...r.php?u=511690
Regards
Old 11-24-2014, 04:57 PM
afxracing's Avatar
First mock up, still a long way to go.
Motorsport Modeling
Old 11-25-2014, 06:39 AM
chris24 chris24 is offline
I wil follow your thread with great interest and I can only confirm what generationx wrote : check your references ! I noticed no less than 6 body versions for the works (or semi-works) Escorts between 1975 and 1980 so you must absolutely know which version you will build first.
Moreover, if the rear arches of the Esci/Revell kit are close to the tarmac specs of circa 1980-81, the front arches are wrong for any version
Old 11-25-2014, 06:44 AM
1975
Old 11-25-2014, 06:55 AM
1976 : front arches and spoiler are different
Old 11-25-2014, 06:56 AM
1978 : the top of the rear arch is now above the belt line
Old 11-25-2014, 07:08 AM
1979 : tarmac version aka the "Monte special". Only seen at the Monte Carlo 79 (works), 80 and 81 (Publimmo) and on a few european events with Russell Brookes (Andrews colors). Big big arches, specific front spoiler and a modified wheelbase.
Old 11-25-2014, 07:19 AM
1980 : very similar to the 1978 forest arches but slightly wider though.
You can notice on this one that the rear wheels well is lower than the front one, as it follows the red line that goes down (from front to rear).
