Old 11-22-2014, 06:24 PM
hidden1 hidden1 is offline
unexpected spark
I was changing the spark plugs in the back are of my 91 grand voyager 6cyl and as i was trying to get to the back row facing the passenger side by alternator there was a quick spark of some type there..i disconnected battery finished plugs and restarted it.
didnt notice anything different.
what could that had been ?,possibly a short there at wiring harness to alternator ?.I didnt see any other wires that were directly powered unless car is running .I also saw a ground strap with a braided cordlike material there also.
Any ideas ?
thanks
Old 11-22-2014, 11:53 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: unexpected spark
One lead on the alternator is a hot battery feed. If you touch that lead to ground with anything conductive like a ratchet, it will spark.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 11-23-2014, 10:24 AM
thanks
i didnt have a tool around it i was just reaching back to pull the plug wire out..
maybe i pushed it against the metal of the engine support/etc .
did that harm anything as to the alternator ?
Old 11-23-2014, 02:21 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Alternator harmed? Probably not. You can check charge output from the alternator at the battery. Should see 13.5+ dc volts with the engine running. If anything it would more likely damage your PCM (engine computer) but if it's running fine with no check engine light then no worries.
