Go Back   Automotive Forums Car Chat > Ford > Fusion
Old 11-20-2014, 01:56 PM
blueMaitai blueMaitai is offline
2014 Fusion Factory Keyless Code
Hi all!
I just purchased a slightly-used 2014 Fusion Titanium from a broker.
The vehicle arrived with only 1 programmed key/key fob, and the owner's manual packet did not include the owner's wallet card that provides the factory-set keyless entry code.
So, I can't use the keyless entry, set my own entry codes, or save my personalized seat/heat settings etc...
Poking around online, I've found the location of the code for the 2013 was usually printed on a bar-coded sticker on the module or fuse box, typically under-the dash to the left of the brake pedal.
That location must be different on the 2014. I can't find it anywhere under the dash, and haven't been able to find any documentation online of where to find it.
Does anyone know where the factory number's located on the 2014?
Thanks, in advance!
Lisa
Old 11-25-2014, 08:08 AM
CptFantaztic CptFantaztic is offline
Re: 2014 Fusion Factory Keyless Code
I will be watching for a response as I just purchased a 2011 with the same problem. 1 key fob and no card for the keyless entry. Hate to pay a dealer but might have to
Old 11-25-2014, 09:40 AM
In researching my missing 2014 Fusion keyless code, I came across the youtube video illustrating where to find the keycode on 2010-2012 Fusions.
Maybe this is the answer you're looking for?
https://www.youtube.com/watch?v=WjiqdoAE1PI
Best,
Lisa
Old 08-09-2015, 09:41 PM
CPGeck CPGeck is offline
The factory key code for the 2014 Ford Fusion can be found on the back of the fuse box located under the dashboard on the driver's side of the car, to the left of the brake pedal.
This video explains how to access the code. You have to be able to read numbers backwards in a mirror, though. :-)
https://youtu.be/pR709EMjZvA
Hope this helpful.
