Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-18-2014, 07:26 PM
mhillmst mhillmst is offline
96 cutlass ciera 3100
my wife used my car today for work then came home and when I started it up to go to my work the rpm's were higher than normal, so I was tapping some components on and around the engine (lightly) to see if a component was stuck, in a hurry to get to work and I tapped on this one component, in the attachment, and the engine stopped, so the component looks like its part of the fuel rail, I think for the injectors, back side of manifold driver side and lines up with one of the manifold bolts, it has a connector on the back side of the component coming from the bottom up and into the part and a small tube that connects with the part as well. Anyone knows anything on this engine and like to help I would appreciate it.
Old 11-18-2014, 07:43 PM
Re: 96 cutlass ciera 3100
also, it starts but won't stay started, with in a second it dies.
Old 11-19-2014, 07:43 AM
maxwedge maxwedge is offline
A990 racer
Looks like the map sensor, wouldn,t cause this. Check fuel pressure for starters.
The Following User Says Thank You to maxwedge For This Useful Post:
mhillmst (04-05-2015)
Old 11-21-2014, 02:46 PM
Tech II Tech II is offline
Like Max said, that is your MAP sensor....check for vac leaks....
The Following User Says Thank You to Tech II For This Useful Post:
Old 02-06-2015, 12:34 AM
jinxyzboi jinxyzboi is offline
Code the ECM. It will tell you whether it's MAP sensor: Low Vacuum, High vacuum and anything else that may be wrong for a start.
The Following User Says Thank You to jinxyzboi For This Useful Post:
Old 04-05-2015, 11:49 AM
Good day, to maxwedge, jinxyzboi and tech II. I didn't mean to forget to thank you all for your knowledge. It was a vacuum issue, the one under the air intake near the MAF. Fixed the issue and haven't had any trouble since. Thanks again.
