Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-11-2014, 09:50 PM
emarkay's Avatar
emarkay emarkay is offline
1984-Just started swaying side-to-side...
Have a 1984 Caprice with 80K miles. Is a daily driver, in excellent condition, no rust, never been hit or abused. Recently it has started to respond to "road bumps" with a lateral shake; literally, 2 or 3 completely horizontal rebounds. If this was vertical, I'd just replce the shocks. If it was a rolling wallow, I'd check the steering components as well as the shocks. Car has 1 testing rebound on all 4 corners vertically, and the ride height is good. Tires are 50% worn, all the same, all at 36psi. The only handling mod on the car is a rear sway bar, which really improved cornering feel. However that has been there for 10 years. All this just started a few months ago, and is consistent, most obvious at 60mph on straight roads. Quick visual inspection on underside shows nothing obvious, but what could this be? Ideas, tests and suggestions welcome!
Thanks!
MRK
1984 Chevrolet Caprice Classic
1998 Oldsmobile Aurora
Old 11-13-2014, 03:00 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 1984-Just started swaying side-to-side...
Shocks. The rocking test does not reveal everything.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-26-2014, 06:36 PM
emarkay's Avatar
OK, thanks! I had a brain booger - was thinking 1957 leaf springs and forgot about the 1984 control arms!
Old 11-28-2014, 08:57 AM
j cAT j cAT is offline
so did you check all the front steering components like the tie rods/idler arms ETC ? 80K the front control arms[no rust] should be like new]. how often do you grease the front end and what grease type is used ? did you do the front wheel bearings @ 30K miles ? lateral slop will be with these Items ..
