2003 Silveardo Gas Gauge
Hi all. I know that the gas gauges on the Silverados have always been troublesome due to faulty sending units. But I'm not sure if the issue I'm having has to do with a faulty sending unit.
When I start my truck in the morning, the gas gauge reads empty. However the moment I start driving, the gas gauge begins reading again at the correct level of gas in the tank. When I come to a light and sit for about a minute, the gauge then reads empty again, and moving again, it begins reading correctly again and remains in the correct position until the truck becomes stationary again. I replaced the fuel pump assembly two years ago. I just started having a problem about a month ago, and I have not been using the truck as frequently as I had before. It's a 2003 with 219,000 miles. I've pulled the pump and checked the sending unit, the pump, and the wiring and everything seems to be ok. Could anyone lend any insight on what the problem could be? May be a ground wire I missed or something? When the gauge reads empty, the "Fuel Level Low" message appears on the dash, so I can rule out a bad gauge cluster (which I replaced last year due to a faulty speedometer). Thanks in advance!
Sean |
Re: 2003 Silveardo Gas Gauge
surprised with a fuel pump replacement this happened .. what was the pump # used and who made it ? I still have the OEM 2000 pump assy....... |
Did you replace the entire pump/sender assy or just the pump? What I find on high mileage, class 8 road tractors that I work on is the float arm develops excessive axial play due to wear at the pivot. This causes poor and intermittent contact with the rheostat, or variable resistor in the sender/pick up assy.
With the truck running in the morning and while the guage reads empty rock the vehicle up and down and sideways. Then check the dash guage. It might just be a worn sender assy. JMHO Your mileage may vary. |
Sean |
Sean |
the rocking causes the rheostat arm to move which then cleans off the pick up. when you replaced this fuel pump did you have to splice in a new connector ? if not then you may have installed the old GM pump that has these issues with the alcohol fuels causing the oxidation of the rheostat contact strip to send the level info to the dash ............and PCM..... if you purchased the airtex pump then you would be lucky to get 1 year out of it. |
Man I sure learned that the hard way! |
Truck does have 220,000 miles on it, so I'm not too worried about it. I haven't had the time to take the bed off and check the pump. It's supposed to be a warmer day on Sunday here in the Northeast so I'll take a look at it then. I'd hate to replace the whole assembly since the pump is still working just fine. May be I can try and clean the contact strip with something not too abrasive. If not, I guess I'll just live with it until this pump fails.
Sean |
