Go Back   Automotive Forums Car Chat > Oldsmobile > Toronado
Old 11-07-2014, 10:13 AM
Kremer210 Kremer210 is offline
Instrument cluster turns off at startup
Ok so my 90 toronado is acting crazy. Which isn't surprising. Basically, when I turn the key to power on but not start it, everything comes up- digital readout, oil pressure, engine temp., climate control readout, etc. But when I turn the key to start it, everything shuts off including the tach, speedometer, and the climate côntrol reads three dashes. It starts and runs fine. If I remove the instrument cluster, the climate control works perfectly. As soon as I plug it back in .... Nothing. Battery connections are good. It throws a code of E047. Any ideas?
Old 11-07-2014, 11:00 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Instrument cluster turns off at startup
http://www.justanswer.com/car/1jqrl-...-turn-off.html
this page tells you what issue usually is and how to fix it
Old 11-07-2014, 12:53 PM
Thank you! I'll have to bookmark that site. I took mine apart and cleaned the crud out of it, put it back and she worked perfectly. Hopefully it's not short lived but now I know where the problem is at least. Thank you so much. I've had this car for 15 years and I can't part with it!
