Old 10-21-2014, 07:24 AM
Bondobob1 Bondobob1 is offline
Taurus/Sable Wheel Compatibility
Looking for wheels and snows for my sons '01 Taurus. Found a set of 15" X 6 used steel wheels w/snows from Direct Tire that were on a '98 Sable. The Taurus has 16" alloy wheels. Will the 15" Sable fit the Taurus?
Old 10-21-2014, 08:06 AM
65comet's Avatar
65comet 65comet is offline
Re: Taurus/Sable Wheel Compatibility
Here is a link for bolt patterns:
http://adaptitusa.com/referencebook.htm
Not only do the bolt patterns have to match, but so do the center bore. Then the size of the brakes. As cars get newer they have made the rims larger not just for aesthetics but also to fit a larger diameter brake disk and larger caliper. That would be my big concern with going to a smaller 15" rim as well as tie rod placement. After that I'd look at the total outside diameter of the tire. Just because it is a 15" rim, doesn't mean that the tire can't have a much larger height to it and end up being larger overall than the 16" and start rubbing, either constantly or only when turning. I'd recommend against it even if it did seem to fit ok. If the total outside diameter isn't the same, your speedometer will be off and it might (I don't think so for this car) throw off your speed sensor and affect the performance.
Old 10-23-2014, 01:55 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
All 1989-2004 Taurus and Sable wheels are 100% compatible. Yes, you can put 15's on an '01 Taurus. Your '01 has the exact same suspension and brakes as a '98 Sable.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
