Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 06-29-2003, 01:44 AM
GTS91's Avatar
GTS91 GTS91 is offline
Cheap FPR mod - adjust timing or not?
I am gonna try to put a bit more fuel flow into the injectors...
Fuel pressure regulator with a vacuum solenoid valve turned on/off by a switch inside the cabin...
Basically the valve will work in bypass mode until switch goes in to block the vacuum going to FPR diaphraghm - giving more fuel onto the rail...
for the extra 10-12 psi, is there any point to change the timing on the fly?
Timing Adjustment Question JAGSARGE F Series 4 05-31-2010 04:50 PM
Mods/Adjustments to a 93 se...please help BigLou93se Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 06-20-2004 09:37 AM
a safe cheap way to adjust camber on accords knorsk Engineering/ Technical 2 08-10-2003 04:17 AM
Cheap effective mods Actuator Europe 0 09-07-2002 07:08 AM
Cheap/Free mods Swonder67 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 09-30-2001 07:42 PM
