Old 10-08-2014, 09:06 PM
bsr2002 bsr2002 is offline
Question Need help identifying a tube/hose
There is a tube/hose going from the air intake duct to the rocker arm cover.
I need to replace it but don't know what it's called to look it up.
Please... Thanx in advance!
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
Old 10-08-2014, 09:19 PM
aleekat aleekat is online now
Re: Need help identifying a tube/hose
If its just a vacuum hose, just pull it off and take it with you. Any auto parts store has reels of different size vacuum lines. Sold by the foot.
Post back, that's what makes Forums Work.
Old 10-08-2014, 10:12 PM
Here is a better pic, more of a tube I guess... The back part was popped out and looked a little melted.
Old 10-22-2014, 09:00 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Crankcase breather line. Usually the end where it goes into the valve cover is falling apart, and it doesn't fit tightly anymore.
It's probably not available through AC/Delco anymore, Try Dorman for a replacement.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 10-25-2014, 01:01 PM
Thanx! I checked with the dealer and they had one in stock! Got lucky, cost $15.00....lolz!!!
Crank case tube Part #24504646
Old 10-28-2014, 07:33 AM
Interesting. I work for an AC/Delco distributor and it was not something we had anymore. I replaced it on my '97 not long ago with the Dorman version.
Would have been nice to get the real deal. The Dorman part apparently covers a few different versions, and needs a little modification to fit correctly.
If you still have the packaging, what's the line code (LC) number on it?
...empty gun rack.
Old 10-28-2014, 03:15 PM
There was no packaging, just the hose with the Genuine OEM tape with the part number on it.
I did order an extra one from these guys here
http://www.ebay.com/itm/GM-OEM-Air-I...55697a&vxp=mtr
It came in a week ago, exactly the same part.
