Old 10-08-2014, 04:24 PM
ellev8or ellev8or is offline
Water pump replacement
92 PA Base
Attempting to replace water pump.
Is a hydraulic jack required to hold up the engine when removing the engine mount? The engine mount (passenger side front) is covering the right portion of the water pump. Although the engine mount has two holes for the remainder bolts of the water pump, there's no room to fit a ratchet or anything to remove the remaining two bolts. It appears the mount must be removed to replace the water pump. Is this so? Please provide me with any details, importantly, how to correctly remove the engine mount.
Thanks in advance.
Zeddy
Old 10-09-2014, 09:59 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Water pump replacement
Yes, support the engine when removing the passenger side mount and bracket...
The Following User Says Thank You to gmtech1 For This Useful Post:
ellev8or (12-07-2014)
