Old 10-06-2014, 09:41 AM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
'89 C2500 rear brakes lock up
Hey fellas,
I just picked up a C2500 with the 350 and 250,000 miles on it. Looks like the brakes were redone in the past few years.
The problem is, whenever you stomp on the brakes, the rears lock up immediately. It will spin out easily in the rain and squeal like hell on dry pavement, so slow controlled stops are necessary.
I'm not sure what could be causing this. Before I go tearing apart the system, does this sound familiair to anybody? Whoever replaced lines to the MC didn't coil them underneath the MC, is that an issue?
Thanks and sorry for the noob question.
-Alex
2008 Tahoe SSV, 2007 Tahoe SSV, 94 GMC K1500, 93 Chev K1500, 91 GMC K1500, 2000 Wrangler Sport
Old 10-06-2014, 03:58 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: '89 C2500 rear brakes lock up
First thing I would check would be if the axle seals are leaking onto the brake shoes. No the coiling will not affect the braking.
Old 10-06-2014, 03:59 PM
j cAT j cAT is offline
Originally Posted by ASJT3 View Post
Hey fellas,
-Alex
could be the rear axle seals leaking oil on the drums. also check rear wheel bearings..
Old 10-06-2014, 08:42 PM
Schurkey Schurkey is offline
Or the wheel cylinders leaking brake fluid on the shoes/drums. Any contamination of the shoes will make for grabby brakes.
While you're in there, assure that the primary shoe is forward, and the secondary shoe is to the rear. Verify that the star-wheel adjuster isn't damaged or seized--and that the shoes are therefore properly adjusted.
If the bearings are defective, the axle shafts will be defective, too. The bearings ride directly on the axle shafts. Thanks, GM. Wonderful engineering.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 10-06-2014, 09:49 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
To be fair to GM, many manufacturers did this on live axles for years. I recall its a "semi-floating axle"
One can get offset replacement bearings that ride on the remaining undamaged part of the axle shaft.
Old 10-07-2014, 12:01 AM
It is a semi-floating axle, but having the bearings ride directly on the shaft is not a defining characteristic of semi-floating. Other semi-floating axles have inner races for the bearings so they don't use the axle shaft as a wear surface.
Semi-floating just means the axle shaft is load-bearing at the outer end, as opposed to a full-floating axle where the hub carries the weight and the axle shaft does nothing but provide torque to the hub.
Yes, I have a set of those on my El Camino. The downside is that the grooved, worn part of the axle shaft becomes a stress-riser. If it's bad enough, the axle could eventually crack there. Fine for Granny, not so great for a performance application.
Old 10-07-2014, 07:49 AM
the axle breaking off at this point I have knowledge of... with these type bearing set ups. it did happen in these older vehicles. one thing about a bearing failure would be a bent axle . these axles do bend easy . so if the wheel hit or got hit then the weak spot is this bearing area and with the bearing getting hot then cold creates a very nice break point.
for the most part this type set up works for several hundred K miles ,but this is with the axle not being stressed out... like easy driving. hard driving bad road will kill this type design .. GM did a poor job with this ...
Old 10-13-2014, 03:42 PM
I checked the rears, clean as a whistle. Lots of pad left too. I'm thinking there's too much power to the rear brakes. could this this be a valve block issue?
Old 10-13-2014, 04:43 PM
Extremely unlikely. Do the shoes seat against the anchor pin at the top--or is one of them held away from the anchor pin?
Old 10-13-2014, 05:48 PM
777stickman 777stickman is offline
I've been following your post and was thinking a bad Proportioning Valve also. Could also be a bad M/C? I've had that happen in the past!! To test this you would need to disconnect and plug the outlet to the rears at the M/C or P/valve to see what kind of braking you have to the fronts.
Does the "RED" brake light come on when cranking the motor?
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 10-13-2014, 11:01 PM
A proportioning valve does not activate until the pressure is quite high. Therefore, no proportioning valve action at typical mild- to medium-braking.
There's nothing in the master cylinder that can provide excess pressure to the rear brakes.
Might be that the front brakes are somehow weak, leading to over-use of the rears.
Old 10-14-2014, 08:24 AM
I also agree that the brake valving will not cause your issue .. as was mention though the front brakes may not be doing the proper brake effort , so the rears are doing most of the braking... this may mean the brake hoses are bad to the front calipers, or the many other reasons that the front brake pads are not being applied at the proper force to balance the vehicles front to rear brake effort..........
with bleeding the front brakes , this should show , open the bleed screw place hose on the fitting and have a helper hit the brakes see how the brake fluid flows...
with bleeder screw open use C clamp push back caliper see what the brake fluid looks like dirty/air/discolored >>>>.
always use a clear tubing so you can see what the brake fluid looks like coming out the bleeder screw...
Old 10-14-2014, 09:52 AM
I'll check on the function of the front brakes and report back.
Old 10-14-2014, 10:02 PM
Maybe the shuttle on the P/Valve, for some reason has blocked off the fronts??
But there are two tanks for front & rear on the M/C and one piston. If the front seal is bypassing it could lead to less press on the fronts and more to the backs.
Which leads into your last quote
57 Chevy 210
Old 10-15-2014, 01:21 AM
Nowhere in the factory literature OR in my own experience does the safety valve "block" one or the other hydraulic circuits when it's moved off-center. OTOH, I hear about it blocking a circuit from forum posters fairly often...so maybe there's something to this after all.
If "P/Valve" is short for "proportioning valve", keep in mind that the proportioning valve has NOTHING to do with front brake operation, which is controlled in part by the metering (holdoff) valve. The safety switch is between the two (front and rear) hydraulic circuits.
There is one actual cylinder, with two pistons end-to end--the primary piston is moved directly by the brake pedal pushrod, or by the power booster pushrod. The secondary piston normally moves in relation to the fluid pressure created by the primary piston, but if there's a hydraulic failure in the primary circuit, the primary piston will move the secondary mechanically.
If there's a failure in the secondary circuit, the primary circuit can still generate pressure when the secondary piston bottoms-out.
Whichever circuit fails, creates additional pedal travel to get the other circuit to generate pressure. Having one hydraulic circuit fail cannot induce extra pressure into the other, but the brake pedal will probably be pressed harder to get two brakes to do the work of four; especially if it's the front brakes that fail.
