Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 10-06-2014, 05:45 AM
shimenen shimenen is offline
crysler lebaron 1979 vibrations
the car is crysler lebaron 1979 originaly came with engin 318 and i planted a 440 h.p engin 1967 and transmission 727 (i dont know what car the transmission came from.)
i have a slight vibration how can i fix it
is it from the turk convector or the poly balance.
thaks shimenen.
Old 10-06-2014, 09:58 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: crysler lebaron 1979 vibrations
Does the vibration happen when the car is not moving, but the engine is running? Then possibly the flexplate is improperly balanced.
If it happens when moving, then there might be something wrong with the driveshaft angle. Also check
The front yoke/slipjoint is proper outer diameter and good spline inside?
The output shaft is straight?
The tailshaft housing is not warped or cracked?
The driveshaft is not bent?
The driveshaft is properly balanced?
The u joint is properly installed and is not missing ay bearings?
The bearing (not the bushing) at the front end of the tailshaft housing is good and properly seated?
The Following User Says Thank You to MagicRat For This Useful Post:
shimenen (10-07-2014)
Old 10-07-2014, 08:35 AM
thanks man! i'll check the list.
