Just got a 35 on my check engine light. From the list of codes this has to do with a radiator fan control, but the fan is not electric. It's a 1994 Ram with 5.2L 318 engine. I'm confused, what does this mean?
Re: 1994 Engine Code
35 engine code= you need truck nuts
Truck nuts?
Yeah, you're missing your truck nuts. That's what 35 means.
I see... thanks?
Just some kid in his parents basement trying to be funny.
Post back, that's what makes Forums Work. |
clearly someone doesn't have truck nuts.
I get the same cooling fan explanations.
Re-run your DTC test.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" ![]() "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 ![]() Time to turn so's you don't burn.
