Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-02-2014, 04:39 PM
not a motor head not a motor head is offline
1989 cutlass supreme 2.8 No start
The motor turn over with spark. I checked fule pressure (40 psi ) had it towed to a garage. He check it over. Called me back said it has to be electronic. The car ran when I parked it. Now it won't start. He also said no pulse to the injectors. But it's in time and good spark. Can anyone help please????
Old 10-02-2014, 06:08 PM
maxwedge maxwedge is offline
A990 racer
Re: 1989 cutlass supreme 2.8 No start
Very tough go diagnose this from here, both the ign. Module and ecu were bad in these cars. You could try tapping the ecu case firmly with a screw driver handle see what happens, the mechanic can't find the problem? All the fuses ok?
Old 10-02-2014, 06:40 PM
Yes the fuse's are good. I was also told that the crankshaft sensor could be bad. The mechanic said was there is no pulse to the injectors. He checked spark, compression, fule psi. Everything I already did. But his small hand computer said no pulse to injectors. And I didn't run across your suggestion. Is there anything else that would cause no pulse to injectors?
Old 10-02-2014, 08:03 PM
Tech II Tech II is offline
If the injectors are not firing, there are 3 possibilities....
Bad ECM....
Bad ICM(no ref signal from ICM to ECM), or open circuit between ICM and ECM...
Bad injector or shorted wiring harness to injector.....this is a multiport system, not sequential.....if an injector is shorted or a wire harness to one of the three injectors(1-3-5 are in parallel, and 2-4-6 are in parallel in another circuit), this will be a huge current draw...the injector driver in the ECM will see too much current flow and and shut down the injectors......see this happen a lot when mice build a nest under the uper plenum, and they eat the insulation....
Old 10-02-2014, 08:14 PM
juicypugh juicypugh is offline
Can someone help me 94 oldsmobile ignition not sending signal to start help plz
Old 10-03-2014, 06:01 AM
Start your own thread.....give year, make model, engine...
Give exact symptoms, and any recent work done to the car....
