Old 09-29-2014, 10:10 PM
Joshaha Joshaha is offline
Exclamation Automatic Trans Question
how does fluid get to the clutch i'm confused about this i know it pass through the valve body then where does it go
Old 09-30-2014, 06:06 AM
maxwedge maxwedge is offline
A990 racer
Re: Automatic Trans Question
What clutch?
Old 09-30-2014, 03:45 PM
The Fluid clutches just like the one for my overdrive gear
Old 09-30-2014, 05:52 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
if its a automatic there is a pump on the front of the transmission that is driven by the torque convertor snout. the pump forces the fluid around inside the transmission to all the parts and clutches as needed
Old 09-30-2014, 06:34 PM
A990 racer
Thanks CRvette69, took 2 moderators to answer that one, clutch, not clutches. LOL
Old 10-01-2014, 02:05 AM
well i ment is it like a engine bearing with passages set up or what i know it has a pump but
Old 10-01-2014, 06:44 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Checkout this link which seems to provide a high level answer to your question.
-Rod
Old 10-01-2014, 06:54 AM
well i found a well apointed diagram of the pump the whole clutch assembly that described exsactly what i was talking about a few mintutes ago it took 3 months of searching but i final found it, howstuff works just told me that the clutches r pressurize by fluid but how the fluid got to the clutches that was important to me
Old 10-01-2014, 06:56 AM
thanks for the help u gave me the keywords to search so thanks
Old 10-01-2014, 12:17 PM
shorod's Avatar
SHO No Mo
The last sentence in the link I provided said, "The pressure for the clutches is fed through passageways in the shafts. "
Just sayin....
-Rod
Old 10-01-2014, 10:07 PM
Well it gave me an idea about it but i need to visualize it
