Old 06-28-2003, 11:35 PM
mreid_7 mreid_7 is offline
Question short shifter rubbing exhaust pipe...how to fix?
i installed a short shifter into my 98 civic ex, but now my shifter is rubbing on the exhaust pipe...are there any easy fixes for this??
Old 06-29-2003, 03:52 PM
BullShifter's Avatar
Aftermarket exhaust? The easiest fix if the shifter is installed correctly would be to have the exhaust pipe bent slightly & not beat with a hammer.
Old 07-05-2003, 12:52 AM
undergroundimports undergroundimports is offline
do this
on every civic if you put a short shift on it will rub the exhause in N or 5 or R depending on the conditions of the exhaust mounts(how far it makes the pipes hang down) you need to just drop the exhaust from the rubber hangers and cut off the heat shield in between the exhaust pipe and the shifter linkage.
Old 07-05-2003, 03:47 AM
Don't remove any upper heatshields, they are there for a reason.
Old 07-05-2003, 04:19 AM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
unless you live in alaska and are looking for all the heat in the interior that you can get!!!!
LS1 RX-7 Zoom Zoom
Old 07-05-2003, 08:53 AM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Re: do this
I've installed short shifters on Tegs and Civics and never had them rub. Get a better one.
Old 07-14-2003, 06:01 PM
hoaks hoaks is offline
I removed the heat shield on mine and it works fine...I recently got the B&M short shifter to replace my generic one from ebay...can't wait to install it
Factory Welds on Exhaust Pipes..How Strong..? solaris=amazing Engineering/ Technical 4 02-09-2005 02:41 PM
Custom exhaust pipes?? How hard can it be?? fbodymustangdude Performance 1 01-16-2005 10:48 PM
Headers, Exhaust, Short Shifters, Intake d4h8a1 Accord/TSX/Accord Hybrid 0 08-05-2003 03:23 PM
check out this deal! exhaust, short shifter, springs AznDragon Integra 6 05-27-2002 04:30 PM
