Go Back   Automotive Forums Car Chat > Buick > Lucerne
Old 09-28-2014, 12:46 PM
jackmalone2001 jackmalone2001 is offline
Windshield Washer Fluid Pump
Hello All!
2006 Buick Lucerne CSX. My windshield washer sprayer is not working. Pushed the button, no sound, no spritz. Blades did swish back and forth though. Checked the fuse, seems fine. Ideas?
Thanks!
Jack
before:
after:
Old 09-28-2014, 08:00 PM
Tech II Tech II is offline
Re: Windshield Washer Fluid Pump
The pump is in the reservoir....put hand on it while someone hits the switch....it will vibrate if energized....if it doesn't disconnect harness and attach a test light to the harness....when switch turned on, light should light.....if it does, need a pump......if it doesn't need to check the circuit back to the switch....
Old 10-01-2014, 03:05 PM
polarzak polarzak is offline
My guess is that it is the pump itself. Mine went a year or so ago. It is an easy fix. Just remove the three lower plastic fasteners in the forward right wheel well, pull back and the reservoir and pump are right there. Pump snaps into the bottom of the reservoir. Pumps are cheap on eBay.
