Old 09-28-2014, 01:42 AM
Huxous Huxous is offline
1992 Mustang LX 4cyl. Needs new transmission. What's it worth?
1992 Mustang LX
4 cylinder
Hatchback
63k miles
(My car knowledge does not go past changing a tire)
The transmission is about done and the car wont go in reverse anymore. The mechanic told me it would cost upwards of 1500 to replace the transmission. The other problems are:
No air conditioning. (Heater works)
Driver side window doesn't work.
Driver side outside handle is broken.
Driver side arm rest fell off.
I like my car and if I wasn't a poor student then I would just pay to fix it. I can't afford to fix it so I know I had better sell it before it rots in my driveway. I know you can get $500 for any old clunker but people tell me that the car is cool and made of steel? What should I try to get for it? I am not in a rush.
Old 09-08-2015, 12:17 AM
347 ranger 347 ranger is offline
Re: 1992 Mustang LX 4cyl. Needs new transmission. What's it worth?
Originally Posted by Huxous View Post
1992 Mustang LX
4 cylinder
Hatchback
63k miles
I bought a 1992 mustang 2.3 running with nothing wrong for $500 so if your car is not running it is not worth vary much1
Old 09-30-2015, 07:58 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Pretty much what he said. Unless you can find a tranny from a junk yard for cheap, I don't think its wise to spend $1,500 on an $500 car.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 10-01-2015, 04:11 PM
MikeCStig MikeCStig is offline
63k miles on it and the transmission is no good... kind of says it all doesn't it?
In the future I would recommend avoiding old 4cyl mustangs. They're problematic in many ways, that's just a simple fact. The only one I can think of that was worse than the lx model was the mustang II.
As for your mustang, consider it totalled. A mustang lx with a bad transmission is worthless.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Last edited by MikeCStig; 10-01-2015 at 08:58 PM. Reason: put more info in after unnecessary mod censorship
