Old 09-26-2014, 03:58 PM
modellmaker.'s Avatar
modellmaker. modellmaker. is offline
Kawasaki ZX-RR 2006 motogp 1st update
Hi everybody,
After I finished the Alfa Romeo I started a new project.
This time I chose a motorcycle, a 2006 Kawasaki ZX-RR motogp bike.
It took a while before I started posting this project because I wanted to get a head start on this one.
Oke, now its time for the pics.
Let me know what you think about it.
The first pics are for the boxart and his content.
I also want to use a lot of extras, bolts, chain and a lot of PE and other stuff.
I got some pics from evilduse as a reference for my build.
Evilduse, thanks a lot !!!
When I ordered the kit I forgot to order the green paint from Zero-paint.
Now I'll have to use a spray can from Tamiya for this build.
These were the first pictures from the start of this project next time more pictures.
I will use the reference pictures to try to make a perfect model, but I will have to modify some small things which I don't like.
You'll see those in a next update
Twitter, Instagram: #modellmaker
Last edited by modellmaker.; 12-03-2014 at 11:10 PM. Reason: add '' 3rd update '' to topic title
Old 09-27-2014, 04:07 PM
MarcoMoto's Avatar
MarcoMoto MarcoMoto is offline
Re: Kawasaki ZX-RR 2006 motogp
Wow, looks like you're in for a very detailed build!
I have this kit in the stash also, so will be watching with interest.
Great reference shots too! Bravo! Marco
Old 09-28-2014, 04:38 AM
Riggers Riggers is offline
Banned
Send a message via ICQ to Riggers Send a message via AIM to Riggers Send a message via Yahoo to Riggers Send a message via Skype™ to Riggers
I concur with Mark, looks like a stunning build....I also have one in the stash, so look forward to the build.
Shame about the TS can, but never mind....
ATB........
Old 09-28-2014, 04:17 PM
evilduse's Avatar
evilduse evilduse is offline
Hey modellmaker!
Glad to see you are finally getting started on your project. Almost forgot about you! Hope to see some pics soon. Good luck!
D.
Old 09-28-2014, 08:35 PM
JimboCO JimboCO is offline
Great kit. With all those extra bits this should be good!
Old 09-29-2014, 01:31 AM
Originally Posted by evilduse View Post
Hey modellmaker!
D.
Hi,
I've been working on the bike for three months now but it's going slow.
I wanted to get a head start on this one because all the extras take a lot of time to do it right.
I'm not easily pleased and want to do it 100%
Within a few days I'll post a new update with more pics.
modellmaker.
Old 10-04-2014, 06:16 AM
Hi everybody,
A little bit earlier than expected but I can show you the first real update
I started with the frame.
There is a mounting bracket for the fairing but It's not the same as the one on the kit.
See the original photo below
bracket on the kit:
bracket on the real bike:
made new brackets...
And modified the frame
gone!!
Finished the frame and painted it with Zero-paints, semi-gloss black, TS-29
I will mount the brackets when the bike is completely done and the fairings are painted.
Now the frame is ready I will add some extras.
On the original photo you'll see a blue transponder.
I'll make this one together with the black square box what's also on the frame.
I'll make this one from scratch
Final result.
There's also a PE part for the blue transponder.
I only have to paint it
And there's a PE part for the rear axle.
I applied some carbon decals on the front and clear coated it
On the front there are a lot of sensor, wires and other hich tech stuff.
I wanted to make a few for a more realistic look.
...made from old plastic...
...drilled a hole...
...and mounted the sensor.
Then made the red sensor...
He is very small.
Modified the red ECU.
On the kits ECU there's a small bracket on it.
This one has to go
...I'll make a new bracket from a old inner tube of a bicycle...
...cut off a little piece, and primerd the ECU
...and placed two rivets in the strip.
...glued the strip on to the bike...
...and mounted the ECU...
...all I have to do is connect the wires and this one is ready.
Done!!
The final sensor to make...
and looks like this...
This is what the frame looks right now, also painted the rear brake cylinder.
This is all folks for now
Next time: the ENGINE.
Untill the next update.
modellmaker
Old 10-04-2014, 08:10 AM
denman2's Avatar
denman2 denman2 is offline
Real nice work .
Looks perfect .
Old 10-04-2014, 03:19 PM
MarcoMoto's Avatar
Agree! Beautiful micro-work!... Did you get the complete Top Studio
super detail-up kit? It has many resin parts, PE,and a very complex wiring diagram in it. If not, you might want to look at their instructions to give you ideas.
Your WIP will be very useful when I start mine... Marco
Old 10-04-2014, 03:35 PM
Hi Marco,
No I don't have the complete Top studio super detail-up kit.
Maybe I should have.
Do you have the wiring diagram?
Thanks for the compliment! I'll do my best to get the best result
Modellmaker
Old 10-04-2014, 03:40 PM
MarcoMoto's Avatar
You can download it as a PDF file from
www.TopStudioHobby.com
Look under their downloads menu... Marco
Old 10-04-2014, 03:51 PM
Thanks!!
Old 10-08-2014, 01:15 PM
gtziaf's Avatar
gtziaf gtziaf is offline
Super build. I follow closely...
Visit our Greek Modelling Forum :
http://scalewheels-gr.com/
Old 11-12-2014, 01:16 PM
Re: Kawasaki ZX-RR 2006 motogp 2nd update
Hi everybody,
It's time for the second update.
I've been busy lately so had little time to place this update.
This time I'll show the engine and I began on the exhaust system.
ENGINE
I started by drilling a lot of small 0.019685in holes because I want to use real bolts.
I will add a piece of clear tube for the oil level so the original piece had to go.
After te prep work it was time to put the engine together and to add some color.
This is the result.
Added the oil cooler
The oil pan will get another color
Done!
Started on the left side with adding some small parts.
That PE stuff is really fragile!!
The valve cover is ready after painting and adding some really small bolts.
Sorry, the valve cover is '' Magnesium '' NOT '' Dark Magnesium '' !!
Then I began on the right side
For the clutch I used the example to get the right color
This is the end result.
Now it's time to mount the engine into the frame
And the last two pics for now are with a mounted clutch.
EXHAUST SYSTEM
Next update
For now this is all.
I'll try to place a little bit sooner a new update.
Let me know what you think .
until next time
modellmaker
Old 11-12-2014, 08:45 PM
evilduse's Avatar
Beautiful work! Makes mine look pretty plain. These pics are definitely going into my moto archives. Congratulations!
The Following User Says Thank You to evilduse For This Useful Post:
modellmaker. (11-12-2014)
