Old 06-28-2003, 10:30 PM
blade34609's Avatar
blade34609 blade34609 is offline
Amp wont turn
Hi,
The problem I have is with my amp.
its a 222 watt Sony Xplode amp.
Whenever I turn the head unit on the amp turns off.
But when I turn the head unit off the amp turn on.
I have my blue wire wired to remote turn on on the amp.
Please help.
Thanks.
Owen
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 06-29-2003, 02:21 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Bad grounds?
Are your power wire / ground wire hooked up into the right spots?
AF's Official Asshole
RIP AUNIE
Old 06-29-2003, 05:52 PM
b18c dx b18c dx is offline
Send a message via AIM to b18c dx
try putting your remote wire to ur fuse box, pick a fuse that only works when the car is on, that will tell you if its ur remote wire
my penis is 12"s. that would make it a foot. does that mean i have to wear a sock on it???
Old 06-30-2003, 12:47 AM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
did you say the solid blue wire from the HU hhmm that would be the power antenna wire you might want to try the remote wire which is blue with a white stripe...
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
starter wont turn, fuel pump wont turn on, guages dont move Tagahoe C/K 6 09-03-2007 03:17 PM
starter wont turn, fuel pump wont turn on Tagahoe Tahoe 3 09-03-2007 03:15 PM
Hedlights wont turn on but ambers wont turn off??!!!!!!!!!!!!!!!!!!!! mayhem143 '96-'00 Civic 0 09-12-2005 06:07 PM
My radio works on ACC but wont turn on when I turn the car on Nuwanda Car Audio 3 05-31-2004 08:30 AM
Amp Wont turn on??? makaveli3004 Car Audio 2 05-19-2004 11:22 PM
