Go Back   Automotive Forums Car Chat > Chevrolet > Uplander
Old 09-18-2014, 04:52 PM
grt grt is offline
smelly exhaust!
Having some issues with my 05 Uplander, its over heated the past 2 days in the morning and then later in the day its fine. I did replace the thermostat not to long ago, also getting a code 301 again(had same code 4 months ago and ended up replacing coil pack, plugs, wires, and #1 cyl fuel injector before it finally solved the problem) now its back again, and the exhaust smells really bad. Im hoping its not a head gasket or cracked head, doesnt seem to be using up cooland, i had to add a little bit
Help please!
Old 09-19-2014, 07:46 AM
Tech II Tech II is offline
Re: smelly exhaust!
A misfire dumps fuel into the cat and can cause the smell.......needs to be fixed or you will need an expensive cat....
