Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 09-14-2014, 05:00 PM
cindalewis cindalewis is offline
malibu classic wont stay running
i have a 2005 chevy malibu classic. a few months ago it started sputtering when we would try to crank it and would take several tries before it would run, then it stopped. So far we have replaced the fuel filter, fuel pump, fuel pressure regulator, idle air control valve and crankshaft sensor, and it still wont stay running when you try to give it the gas, it dies.....any ideas?
Old 09-14-2014, 09:50 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: malibu classic wont stay running
Did you scan the ECM for trouble codes? If yes, what did you find?
Old 09-14-2014, 10:32 PM
there are no trouble codes showing any more but the last one was po131...
Old 09-15-2014, 04:19 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Have you checked the fuel pressures at the rails?
If so what are the number?
Check the pressures at KOEO and KOER
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 10-23-2014, 11:41 AM
tractorboy's Avatar
tractorboy tractorboy is offline
when the car is running is the brake pedal firm or spongy, why I ask is if spongy could be a vacuum leak...I say could b/c there are other issues that can cause a spongy brake pedal . As you have found throwing new parts at a car seldom fixes the issue. What does your air filter look like ? is it clogged, check all your vacuum hoses especially the one that goes to the MAP. what does your oil look like is it milky looking with mayo like stuff at the top of the dipstick is there oil in the coolant overflow bottle ? when dark and engine running open the hood and look for arcing of the spark plug wires.
