| WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
WIP R32 GT-R S-tune
Hi all,
while i cant work on other projects, i've started this one ive been planning on for a while its a fujimi R32 gt-r nismo version, but not s-tune (so it has group A/N1 bumpers, wings and side skirts) its an ok kit but i thought i could improve on it with a few left over parts lying around...... what inspired me was i have a sticker kit for the nismo Z-tune which has similar graphics used on the nismo s-tune - which was a modified R32 from nismo in 2000, im not sure about the story behind it but it happened roughly 10 years after the r32 was first produced....pretty cool anyway, i also had a spare set of nismo wheels from the tamiya R34 v-specII kit, and also made the Tamiya brakes fit as well so no fitment issues for the wheels now. i modified the suspention a fair bit, not only to make the tamiya brakes fit and align to the guards correctly, but also lowered the right hight a little bit, just to where it probably should be on the std car. it was originally too high to start with, and to be honest i could have gone a little lower but its fine for this model. im happy. now i know i need lots of pics to watch a thread so heres lots of pics! first i set about correcting all the imperfections and fitting the body kit parts. group A / N1 front bar has extra ducting ![]() group A / N1 side skirt add on ![]() group A / N1 lip under rear wing gets glued on ![]() when wing is fitted after paint will look like this.. ![]() the group A / N1 kit also includes an intercooler which i was happy with, good thats one thing i dont need to scratch build! ![]() the front suspension had the majority of the work, there is the set up without the brakes in place. it uses the fujimi struts, lowered a little, with all new alignment which required new top mounting point, lower mounting point moved on strut itself and steering point moved as well ![]() here you can see the original hole plugged and a new hole in a bit to allow clearance for new wider rims with different offset. ![]() and the result of the suspension mods
Re: WIP R32 GT-R S-tune
nice! looking forward to more updates
olly olly oxen free |
thanks, it'll be primed today, hopefully so silver paint on it very soon too!
Nice work - watching with interest!
Looking good.
Post some more pics Cheerz |
its prepped ready to paint tomorrow, update soon!
i have 3 to paint tomorrow
This thread needs MOAR pics and updates, can't beat a nice R32!
May I ask why you put a bit of putty on the top of the headlight area? KUTGW my friend
sorry this one came to a hault, i had two other models that i painted and they needed stripping so progess on all three WIP stopped. |
this one received a clear coat today, should have more progress shots very soon
heres some pics of it clear coated.
this is without any sanding/polishing, i'm considering just leaving this one as is....its not perfect but its good enough for me i think. also i have lots of other stuff going so i really dont have the time to be fussy, i just want it done! im very happy i painted it silver, it was really just painted silver as i could be bothered mixing anything special for it, as i was thinking about a gun metal grey or something slightly different. silver just shows all the body lines of the R32 so well, so i couldnt be happier.... ![]() ![]() ![]() ![]()
for anyone interested it was airbrushed with auto air aluminum base (fine), and cleared with automotive acrylic. (pressure pack)
Yay an update!
![]() I think it looks spot on, silver is a very common colour in 1:1 cars, yet some cars look their best in silver. Personally I think you should just give it a little polish with course and then fine polish and it will be perfect ![]() May I just ask something, how do you find airbrushing silver? I had a little play with silver the other day with 4 spoons, with various methods and found that the spoon that I sprayed with a few medium to heavy coats looked an awful lot better than the spoon I did with about 8 mist coats. None of them were clearcoated but just the finish on the heavy (ish) one looked ten times better. I just wondered what the method was with the Skyline or if you have any tips and tricks so to speak? Sorry for the long post I just find silver hard to get right as opposed to black, which is generally the hardest colour to spray! |
generally speaking you are correct, if you spay any metallic too light, the metallic flakes sit up higher on the surface or something, as the fleck is a lot more noticeable when only light coats are applied. if med/wet coats are applied, then the metallic fleck is able to act more naturally and blend in nicely to the underlying coats. but..... this particular paint is a water based paint that takes a fair bit to dry (sometimes best using a hair dryer between coats, thats how slow it dries) so it is a bit different to use compared to others that have more 'solvent' based thinners. so, i actually spray this in fairly thin coats, otherwise it runs or the pigments kind of pool together, therefore it has a very un even distribution of the silver pigment/fleck. luckily, with this one i can get away with a light/medium final coat as its a very very fine fleck. i hope that makes sense
That makes perfect sense sir thank you very much!
Now keep the updates coming
