Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-06-2014, 06:43 PM
nobeyracer nobeyracer is offline
2001 dodge 2500 speedometer
i have a 2001 dodge 2500 cummins and the speedometer and odometer have stopped working. what can i do to fix this? fuse? or wire?
Old 09-07-2014, 03:53 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 2001 dodge 2500 speedometer
The speed sensor, mounted on the rear differential, or it's wiring may be the issue.
You should have a P0500 trouble code.
Turn the keyswitch On, then Off, then On, then Off, then On and look at the odometer display for trouble codes.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 09-07-2014, 06:19 PM
i did the "on" and "off" circulation and it came up with five codes, wondering if you could tell me what the others meant, and maybe how to fix them!
P 1622
P 0622
P 0122
P 0500 (the one you told me)
P 1693
Old 09-08-2014, 03:59 PM
AF - Advisor
I'll go one better,
Here's a downloadable 2001 service manual.
The download is kinda slow but worth the wait.
http://dl.dropbox.com/u/42304/2001DodgeRam.pdf
DTC's start on page 2789
We'll discuss any or all.
Old 03-25-2015, 10:33 PM
02dodge 02dodge is offline
Hi I haven't had problems with the speedometer, yet nock on wood. My problems have been all fuel, went through two fuel pumps, injector pump. so I put a FASS fuel system in. I just wanted to send so info your way. have you put the low pressure light in yet for fuel pressure. If not I recommend you do it a must it flashes to tell you your pressure is low to the point where you will burn up your injector pump. A $1600.00 plus repair not including labor to do it.
The Following User Says Thank You to 02dodge For This Useful Post:
Chris Stewart (03-26-2015)
Old 03-26-2015, 08:14 PM
AF - Advisor
I have a lift pump fuel pressure gauge inside the cab to watch the fuel pressure very close.
