Old 09-06-2014, 04:48 AM
Firebird1 Firebird1 is offline
Send a message via AIM to Firebird1
Check engine light comes on & goes off
I have a 93 3000gt VR4 with 214,000 miles on her at the moment. As I am cursing at a speed of 55 the check engine light comes on and stay on for a while then as sudden as it came on it goes off still driving at 55 or less depens on traffic. My question is why is this happening? I took it to AMMCO to have the code check but they could not because the check engine light is not constantly. I do not have a code sxanner for the car to read the codes if any. The engine runs strong I tried to see if I could get the check engine light to come on but to no avail. Could it be a sensor going bad or the ECU I had trouble with it before and had the dealer replaced it. I'm here. Help! Thank you in advance.
Old 10-09-2014, 10:43 AM
toddrs93's Avatar
toddrs93 toddrs93 is offline
Re: Check engine light comes on & goes off
Did you ever figure this issue out? Probably something electrical.
I can take a look if you still need help.
edit: I just saw the other thread so I guess you got it.
Old 01-16-2015, 05:03 PM
No the car won't run. It died on me just before I was to head to florida. I think It's a sensor either the crank sensor or the cam position sensor. it's almost apart now just need to get the flywheel off so I can remove the timing belt cover plate. it's cold out there now.
