Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-03-2014, 04:58 PM
GESYMSB GESYMSB is offline
Unhappy Camry 1991 Key Cylinder
Can some one help me here, cant find info on how to replace
the Key Cylinder, it is damaged key will not turn an is on lock position.
I want to remove it and replaced.
The car is a Toyota Camry 1991, V6, 5 Speed, DX, 4 Doors Sedan.
Key is on the right side with lock button on top.
Thanks...........
Old 09-04-2014, 12:03 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Camry 1991 Key Cylinder
Many times it's not the cylinder, but a worn out key that causes this problem. Before replacing the cylinder I would try to have an original key made by the dealer. You will need the 4 digit key code and proof of ownership. If you don't have the key code, the dealer may be able to look it up from your VIN. I would call your local dealership and speak to the parts department.
Mike
Old 09-04-2014, 01:05 PM
Wink Re: Camry 1991 Key Cylinder
I already un-lock the cylinder, when I have time will put a new one
as now, is working ok.
Nothing wrong with my keys, thanks
Tags
camry , cylinder , key
