Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-01-2014, 12:08 AM
Chris2007 Chris2007 is offline
inner thermal bypass pipe
Starts at the water pump area, goes.underneath the plenum, then "connects" to the thermostat housing or behind it.
Question is _how_ does it connect? Is it simply a friction fit (with an o-ring?) like the way the outer bypass pipe plugs into the area around the water pump?
Old 09-01-2014, 09:05 AM
Blue Bowtie's Avatar
Registered Offender
Re: inner thermal bypass pipe
What year? What engine?
Old 09-01-2014, 10:17 AM
2001. The layout is the same on most of these 3.4s from those years regardless of vehicle even.
Old 09-01-2014, 09:00 PM
Tech II Tech II is offline
I don't believe there is an o-ring involved.......it is a dry fit...if I remember correctly, there is a "ridge" on the pipe, when the pipe is fully seated......think we used a horse shoe shaped tool to bang it into place at the ridge...
Old 09-01-2014, 10:22 PM
So therefore couldn't most of that pipe be hacksawed off (after the bend) and it be rotated to point towards the front of the car? If so, I'd just clamp heater hose and route it OUTSIDE the plenum. It's a stupid design.
Besides I really don't want to spend 2 hours at a junkyard pulling that pipe out. I *had* to get this done yesterday, but it rained. Don't have time to order a part and really don't want to anyway.
Old 09-02-2014, 11:56 AM
You are not going to put a junkyard one in, you will damage it on removal....
And you can't just rotate it, it will leak.....
Old 09-02-2014, 12:05 PM
Damn it, I guess I'll have to order 1 then.
What about sawing off so there's just a vertical segment sticking out? I could use a hose bender to direct it horizontally towards the front of the car.
