| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Can anyone explain, which engine (car) is better:
Mitsubishi Pajero Sport (Asia Spec) 2.5L 16-valve intercooled turbocharged DOHC Common Rail Di-D (High Power (model 4D56) 2,477cc Max output: 131 (178) /4,000 Max torque: 350 (35.7 /1,800-3,500 Electric Common Rail Direct Injection 5 speed (auto) INVEC-II with sports mode With Car Weight: 2710kg Diesel Toyota Fortuner (Asia Spec) 3.0L 4cylinder, 16-valve DOHC Intercooler VN Turbo (Model 1KD-FTV) 2,982cc Max output: 120 /3400 Max torque: 343/1,400-3,200 Common Rail Direct Injection 4 speed (auto) With Car weight: 2510kg Diesel Thank You. |
Re: Engines: Mitsubishi 2.5L DOHC or Toyota 3.0 DOHC
Both engines are very similar - since the Toyota engine is larger yet produces about the same power, that means that the turbo is smaller or produces less boost. Which in theory means it should be more reliable, but also means it may use more fuel. This is compounded by the fact that the Toyota only has a 4 speed transmission wile the Mitusibishi has a 5 speed.
Dr. Disque - Current cars: 2008 BMW 135i M-Sport 2011 Mazda2 Touring Past cars: 2007 Mazda 6S 5-door MT 1999 Ford Taurus SE Duratec |
| The Following User Says Thank You to drdisque For This Useful Post: | ||
AlidMisli (09-03-2014)
Thanks drdisque really appreciate the reply.
So in other words? In terms of reliable, toyota will be reliable because of having a "capacity" and produce less stress to produce the power. Hence built with low turbo boost. However, more fuel consumption will requires to produce "the power". But on Mitsubishi with lesser "capacity", it is able to somewhat bring more power in theory as the turbo will be slightly working harder and stresses the engine thus; these mechanism are not reliable. However it will be more fuel efficient compare of toyota, so less fuel wastage. Interesting! The Toyota car is actually having 65L capacity tank while the Mitsubishi having 70L. In conclusion, performance ride, Mitsubishi is better? but Toyota is reliable. Last edited by AlidMisli; 09-03-2014 at 06:58 AM. |
Yes, you have the theory right.
Also, you'll note that the Toyota is 200kg lighter, so in practice, they may actually get similar fuel economy.
